Hopper 3 antenna pointing
  • WELCOME TO THE NEW SERVER!
The local programming for the Virgin Islands, Zip Code 00801, is on the western arc, weird as that may sound. You'll want a 1000.2 Western Arc LNBF with a Solo Hub. Not sure about the 129 unless there are some other channels on there but i bet the signal for it and the elevation are extremely low
Station Channel Orbital
ELMIRA, NY - ABC (WENY) 8 / 9028 110
ELMIRA, NY - ABC (WENY) HD 8 / 5180 119
NATIONAL PBS NETWORK (PBS) 60 / 9047 119
PUERTO RICO, PR - CBS (WSEEP) 18 / 9044 110
PUERTO RICO, PR - CBS (WSEEP) HD 18 / 5181 119
PUERTO RICO, PR - FOX (WSJX) 24 / 9046 110
PUERTO RICO, PR - FOX (WSJX) HD 24 / 5183 119
PUERTO RICO, PR - IND (WVXF) 10 / 9049 110
Reactions: JSheridan
If you are on the west slope of anything in USVI 129 is 16 degrees above the horizon, 110 about 34, 119 about 26.
Reactions: HipKat
Arc/OrbitalReflectorAzimuthElevationSkew
WA • D1000.2 • 270 • 26 • 158
So I got the solo hub and the lnb and did a late night last night setting them up. I can get the 110 and 119 sats but I can't get the third pickup to find anything while keeping the 110 and 119 locked. Also thanks to all especially HipKat for lending his expertise.
Reactions: HipKat
I'll bet that 129 is so low in the sky, possibly something is blocking it? It boggles me that you are so far east and have to use western arc, especially picking up Elmira channels. Elvira is a primarily eastern arc market
Reactions: pattykay
