GALAXY 19 Ku @ 97W
That is another fine tuning adjustment.Use the signal on the transponders you already found set it to where you get the highest signal.
Ok will do that thank u..could that b why the other tranponers are not in or the combination of the 2
Thinking about switchen from 97 west to galaxy 17 91 west . Wat do u guys think? For ku is there more fta programing?​
91w KU is a good Satellite for feeds. I have a fixed dish at that location for blind scanning. I find some good finds mostly in the evening and weekends.
Stay on 97w ku more channels 91w has just feeds.
Ok will stay on that sat..what does frquency step do for a blind scan? What does terrestrial scan mean?..is there a way to get the program info in the guide? They all say no info.
The freq. step is how big a jump it will take in scanning a freq. range. Too large and you will miss stuff. Go the smallest it will go and you will not miss anything in a scan(of course assuming your dish is aligned etc.)
It will make it slower, but more detail is obtained.
Terrestrial scan is for an OTA antenna.
There is very, very little guide info available in NA. So in short, no, you will not be getting guide data.
Reactions: danristheman
Use TitanTV for your programming guide. That's what i use, and i customized it will all my Cband/KU channels.
Yeah, I should have mentioned that. That is what I use also.
do u load that in the box or just view it online? iv found titan tv online just not sure how to custimize it fo galaxy 19.
Ok I did move the dish ..i seem to be picking up more to then before. So far these transponders are in 11836 11966 12146 12177 11960 12028 11706 12141 12182 but i seem to still be missing alot. What should I do and try to adjust first? Any suggestions?
Hopefully you can see the TV from your dish, or have a satellite meter. Tune to a TP that comes in, but is weak. Without loosening any bolts, gently pull the dish up/down, left/right. Watch to see which way makes the signal quality go up. Then loosen the bolts a little and adjust the dish in that direction a tiny bit. Tighten. Adjust the skew very slowly each way until you get the best possible signal quality. Once you have that weaker transponder as strong as possible, do another blind scan. Some more, weaker TPs should show up. Then from there, pick the weakest one that comes in and repeat the process.
Reactions: FTA4PA
