Today, I was still on software version U249 on my HWS, so I decided to try the manual update. To my surprise, I downloaded U703 (with a date of 7/30/18). I don't think I have seen U703 mentioned yet. I wonder what has changed?
OK. This is probably the HWS release that is equivalent to U521 for the Hopper 3.
You should now see the new YouTube Kids app. This is a case where you are getting something before the Hopper 3 does.OK. This is probably the HWS release that is equivalent to U521 for the Hopper 3.
also the joey has a software update also too that inculded the new screen savers tooExactly. It was released on the 27th and is making it's way out in the wild.
There's also new screen saver screens.![]()
I noticed the screen savers and also the ability to make the star button into a few different options, other than the format setting.Exactly. It was released on the 27th and is making it's way out in the wild.
Those have been there for awhile, same with the pound buttonI noticed the screen savers and also the ability to make the star button into a few different options, other than the format setting.
Did you let it sit after it rebooted?I just tried a forced update, and it's still saying U249...![]()
MENU, MENU, TOOLS, then look to the right of the screen where it says UPGRADE SOFTWARE.How do you force a software update?
Hopper to Hopper playback trick play has been fixed and a few other things.![]()
Haven't had time to run through everything, but noticed while watching a program from the other receiver, pushing the stop button will freeze the recording, pushing the stop button again does nothing. Using the pause button the timer clock starts running. The only way to go back to live programing is to use the guide or turn the receiver off and back on again.
I'm using two Hopper Slings.I haven't seen that one here. I just checked again while playing a recording from the other Hopper 3 and when I pressed the stop button it pulled up the playback stopped selection screen just like it should, and View Live TV drops out of the recording to live TV.
