CBC Feeds on 115W
Are Canadian CBC feeds scrambled or itc on 115W?
Would like to know before installing another dish.
Thanks. VE2FCZ
I don't think there are any "CBC" feeds on 115w? Can you confirm you mean C-band or KU band, and what the name of the sat is so I can double-check?
Eutelsat 115 West B at 114.9 W is where CBC/Radio-Canada has occasional Ku feeds. There's also a 24/7 mux of three Radio-Canada (French) channels ITC here. Lyngsat has the details, though they only list two of the channels, and show them in SD rather than HD.
Note that CBC/Radio-Canada is using the Ku4 beam of Eutelsat 115 West B. Reception of this beam tapers off the farther from Canada you are.
Reactions: comfortably_numb
Well, there's some Canadian feeds on the KU side that aren't scrambled,
12006 H DVB-S2 8PSK 11440-5/6
Too bad can't get here in New Mexico.:( Too weak to lock it in. I guess the Canadian are too shy go in the clear in the Ku band world. Wish their footprint go down further south in the main USA.:hungry
Reactions: raydio
I can get it here in NM. All 3 channels in French. I had to set the usals to 114.5 for some reason but the feeds work. There are sports feeds from Canada and Mexico along with news feeds from Mexico that I have seen on the satellite
Sent from my VS995 using the SatelliteGuys app!
Reactions: N5XZS and raydio
Still no luck on CBC French channels on the Ku band.:(
Just barely just a blip 0 to 10 on the signal strength here in New Mexico with a 1.1 meter dish.:p
That's surprising. My 1.2 gets it just fine and I don't think I'm that far from you. Maybe adjust your elevation? Do you get the multi channels on 118w? 6 pictures on one screen. I adjusted my dish and get both muxes just fine.
I use usals and the sat is saved at 114.5. The only sat that is .4 degrees difference.
Reactions: raydio
Going have to wait till the crappy weather goes away here in New Mexico. May get 1 to 4 inches of snow, but don't get very much here in Albuquerque metro areas.:p
A soons as the weather clears out the I will tweak my dish.:hungry
This is what I get at 114.9W
I don't know what that means. I just set the antenna setting until I found the feeds. 114.5w works best. There is curling on now backhaul at 12011V15000
Lnb is in the same spot on dish for all the satellites. I don't move that.
