The other ports support 1080p/i 720p at 60 hzI've been looking at the manual for your TV. It is very important that you plug your Hopper into HDMI port 5. It is the only port that accepts 60hz and the Hopper is 60hz for both HD and 4K.
What does that do?You may also want to try unplugging the tv. Then hold the power button on the tv down for 30 seconds. Then power back up
Drains all of the power from the tv so a hard reboot. From reading the vizio forums they are notorious for needing this done to clear various issues. Not sure if there OS holds on longer in memoryWhat does that do?
But the Hopper can be a 4K receiver. It makes sense to permanantly set up for what that receiver can accomplish.The other ports support 1080p/i 720p at 60 hz
You don't know what else he has though. Could have a ATV4K which should probably occupy that portBut the Hopper can be a 4K receiver. It makes sense to permanantly set up for what that receiver can accomplish.
I know he has a Roku. I also know he is passionate about 4K on the Hopper 3. If he doesn't use that port for his Hopper he will never see 4K out of the Hopper.You don't know what else he has though. Could have a ATV4K which should probably occupy that port
Not yet. That's why I asked him to press Menu on his remote. That would at least tell us whether the TV is capable of any picture at all.Maybe I've missed it but has he indicated that the TV works at all, with anything ?
So you hooked the Hopper up to another TV? Did you get a picture?Did one thru three what you said the power light on the tv left bottom side keeps going off and on did power cycled a bunch of times unplugged the power cable from the tv drained the power from the tv no such luck thinking it is the tv that is the problem?looks like it is a power up problem and there is no picture
You haven't given us enough information to even be sure the TV is the problem, much less the main board. Tell us EXACTLY what you have done and what results you have gotten.Input top left power to the right three buttons Amazon, Netflix iHeartradio keypad on the bottom of the remote. Vizio TV is M50-C1: do you guys think it is the main board is the problem?
Yeah, seems like the most basic level of "troubleshooting" has been overlooked by him. I mean, it's a smart TV - turn the damn thing on with NOTHING connected and you'll get a pretty vibrant menu system/interface that makes it obvious if the TV itself works.Not yet. That's why I asked him to press Menu on his remote. That would at least tell us whether the TV is capable of any picture at all.
I caught his reference to the ROKU not working as well and immediately thought, "uhhh, maybe it's the TV...".Best I can tell no. I tried as did others have but not really a straight answer. He seems to be saying the Hopper and Roku do not work.
