1000.2 wa with 722. Tv1 shows no signal but tv2 works. Cables & connections are good. Tv1 was previously working and gradually lost 119 then nothing. Occasionally after a hard reset, Tv1 will work and tv2 has no signal. Im lost. Any ideas?
OP has a previous thread on this issue, where it was stated "Complete Signal Loss."Stupid question, but have to ask based on language used. Does it say "No Signal" or "Complete Signal Loss"?
Have you tried replacing the separator at the back of your receiver, to see if that helps? I have a spare separator I could send you if you want to try it. Let me know in a PM.1000.2 wa with 722. Tv1 shows no signal but tv2 works. Cables & connections are good. Tv1 was previously working and gradually lost 119 then nothing. Occasionally after a hard reset, Tv1 will work and tv2 has no signal. Im lost. Any ideas?
Tv1 says complete signal loss. I look at the installation screen, no signal strength for Tv1 output. Tv2 shows 60s-70s.IMHO those symptoms are tough to diagnose. Do you have any other receivers, e.g. older ones no longer on your account, that you could try to see whether it's the switch in the LNB or the 722 itself? Could you clarify whether you meant the TV1 tuner, or rather the TV1 output, is suffering LOS most of the time? How is it you know that the cables and connectors are good? Water can infiltrate those outside connctions and confuse things.
Complete signal loss, shows no signal strength on installation screenStupid question, but have to ask based on language used. Does it say "No Signal" or "Complete Signal Loss"?
722 reciever signal problem
My 722 reciever shows signal strength on TV2 in mid 60s. On TV1 it's much lower. Recently, TV2 will give complete signal loss message and TV1 has audio&video. I unplug to reset. Sometimes it works, mostly it doesn't. How can the signal strength be so different? Why if TV2 is higher it gives...www.satelliteguys.us
I do have an older receiver that I could try.Tv1 says complete signal loss. I look at the installation screen, no signal strength for Tv1 output. Tv2 shows 60s-70s.
I'm beginning to lean in that direction. I'll do a swap to see of fixes the problem. Thanks for your replyI had the intermittent "Complete signal loss" on 3 different 211's.. reboot and worked for short periods of time.. Receivers were toast...I believe it was something to do with the power supplies not providing enough voltage
