Hey did you ever find you a C band Dish?, the best two place to look is facebook marketing, and craigslist you might have to drive a few hours and bring a friend..Team,
Where can I purchase a 8 or 10 foot mesh dish for C band reception?
Thanks,
4311 wade
Yes I found a dish locally.Hey did you ever find you a C band Dish?, the best two place to look is facebook marketing, and craigslist you might have to drive a few hours and bring a friend..
Ok nice find, the first thing you want to do is power wash it with some bleach and water, next you going to have to do the string trick to make sure everything centered. Did it come with the mount for it? You going to need a heavy duty actuator arm for it, since it is fiberglass.. C band only or C and
Hello Huston Rockets,Ok nice find, the first thing you want to do is power wash it with some bleach and water, next you going to have to do the string trick to make sure everything centered. Did it come with the mount for it? You going to need a heavy duty actuator arm for it, since it is fiberglass.. C band only or C and Ku band?
You are correct! Aluminum eight and a half feet across.It looks like aluminum with a sorta button hook thing for the LNBF to me……
do you have the rest of the mount/actuator?
The mount looks damaged to me but you might know better.You are correct! Aluminum eight and a half feet across.
Is this button hook style LMB?You are correct! Aluminum eight and a half feet across.
Thanks for the education!It is a button hook mount.A button hook or a three leg or four leg,is a mounting point for the feed horn,the L N B,attaches to the feed horn.
If the LNB support legs are in too bad a shape and you are handy you can replace them with similar sized metal electric conduit. You just need to make careful measurements of the originals, then cut and shape them so you duplicate their length and position exactly as it is critical to get the LNB at the proper location to receive a good signal. Paint them to match your dish and you are good to go.Thanks for the education!
mine has 3 legs that are a little bent. I will straighten them up the best I can.
[QUOTE="FTA4PA, post: 4637710, mem...lic-Tubing-Steel-0550005000/202068069[/QUOTE]If the LNB support legs are in too bad a shape and you are handy you can replace them with similar sized metal electric conduit. You just need to make careful measurements of the originals, then cut and shape them so you duplicate their length and position exactly as it is critical to get the LNB at the proper location to receive a good signal. Paint them to match your dish and you are good to go.
https://www.homedepot.com/p/1-2-in-x-5-ft-EMT-Electrical-Metallic-Tubing-Steel-0550005000/202068069
https://www.homedepot.com/p/1-2-in-x-10-ft-Electric-Metallic-Tube-EMT-Conduit-853428/100400405
https://www.lowes.com/pd/Common-1-2-in-Actual-50-In-Metallic-Emt-10-ft-Conduit/3129551[/UR
apologies,
