You lost me. What is the trick play issue? I will try it out.See any differences, e.g. fixing the trick play issues?
Can't wait to see Howard's next. He is brilliant.
I wouldn't bet the house on it….Plenty of opportunities tomorrow to see if they put a fix in H310 for the ongoing 4K HDCP "error" issue.....
Let's say you're watching live TV, but you miss something. You skip back 10 seconds to hear something again, and after doing that and before you get to hear the part you missed, it jumps to live! You can try skipping back multiple 10 seconds. At some point (-1 minute?) its chase play is fine. Occasionally, while hitting skip forward or back multiple times, it sometimes skips all the way back to the beginning of the buffer. But it's favorite "trick" is to skip unbidden to live. Very annoying. My H3 did not do this when I first got it.You lost me. What is the trick play issue? I will try it out.
I do have a similar problem like that from the H3 but it is only when watching a recording from an OTA program sub channel 04-03 from St Louis. It drives me crazy. It records tonite so I will check it tomorrow to see if it is fixed and let you know. We don't have any problems with the other recordings. We hardly watch any live TV and when we do we hardly ever hit the skip backLet's say you're watching live TV, but you miss something. You skip back 10 seconds to hear something again, and after doing that and before you get to hear the part you missed, it jumps to live! You can try skipping back multiple 10 seconds. At some point (-1 minute?) its chase play is fine. Occasionally, while hitting skip forward or back multiple times, it sometimes skips all the way back to the beginning of the buffer. But it's favorite "trick" is to skip unbidden to live. Very annoying. My H3 did not do this when I first got it.
OK, I manually triggered this update. I'll try the Joey myself later.
They're already off the Hoppers before the update.I saw a few days ago that Locast lost their case (to be able to carry streams of local TV channels), and were going to cease operations within like 2 days. Could be an update just to pull Locast off the list of apps.
Thanks. My H3 has H310 now. But my J3 is still on J509 and still has it after a reboot. It still jumps to live.It records tonite so I will check it tomorrow to see if it is fixed and let you know.
Thanks. My H3 has H310 now. But my J3 is still on J509 and still has it after a reboot. It still jumps to live.I see no option to upgrade a Joey. Perhaps after it does its own reboot at 3AM?
And this morning, I see J510. A single press of the skip back 10 seconds button inexplicably skips back 20 seconds. After a few seconds of chase play at -20 seconds, it again jumps to live.I manually updated both of my Hopper3 receivers to H310. According to the Hopper3 screen my Joey3 should have J510 but like Krell my Joey3 stayed at J509. I even did a full power Reset of my Joey3 but it stayed at J509.
And this morning, I see J510. A single press of the skip back 10 seconds button inexplicably skips back 20 seconds. After a few seconds of chase play at -20 seconds, it again jumps to live.![]()
My Joey3 now had J510 also. The first time I press the skip back button it skips back 20 seconds. The next several presses of the skip back button always skip back 10 seconds.
I have tried it several times and half the time it would jump back to live. Whether it works correctly seems to be tied to how the button pushes are timed.
@thekrI still see the same issue on channel 04-03 from St LouisI do have a similar problem like that from the H3 but it is only when watching a recording from an OTA program sub channel 04-03 from St Louis. It drives me crazy. It records tonite so I will check it tomorrow to see if it is fixed and let you know. We don't have any problems with the other recordings. We hardly watch any live TV and when we do we hardly ever hit the skip back
Interesting. Of course the reboot of the Joey did nothing, since it came right back up with the old software. I let it reboot itself at 3AM. But I suppose I might have seen something happening when it went into standby.Just for reference, a Joey will only update if its on standby with the host Hopper connected.
