I'm new to FTA but am wondering if anyone have hooking up a amiko mini hd265 wifi to a visio flatscreen TV, can't get mine to work
Not had any reported problems. Need more info.I'm new to FTA but am wondering if anyone have hooking up a amiko mini hd265 wifi to a visio flatscreen TV, can't get mine to work
to SatelliteGuys!!!!ONot had any reported problems. Need more info.
Ok hooked lnb ,hdmi cables then power turn on it shows amiko on TV then shows wifi devise plug in then shows _ _ _ _ on amiko that's all blank TV screen
I forgot to say when I. Turn it on a press menu that's when it shows wifi device plug in then 4 dashes then blankThis is because you have no channels scanned in. You have to hook up a working dish and go into the menu, set the settings to your setup and scan in the channels.It defaults to a screen of the last channel you watched. In your case you have no channels scanned in. So, you have to get some scanned in.
I have a v8 sat finder and have lock on satellite and run scan on it with no problems this I understandI forgot to say when I. Turn it on a press menu that's when it shows wifi device plug in then 4 dashes then blank
It does this all on its own. Maybe a video type mismatch. Some reason your TV does not like it. I see this about every 2 years. Try a different TV or computer monitor. There is a V.Mode button on the remote that cycles through the different modes. press it wait like 10 seconds press again, rinse and repeat. It will go through several video modes. I would try a different TV/monitor and/or HDMI cable first. The cables that ship with the unit, may for some reason not like your TV.I forgot to say when I. Turn it on a press menu that's when it shows wifi device plug in then 4 dashes then blank
Just tried a different hdmi cable and all is well now thanks ke4est you got 10 stars from sanpat .It does this all on its own. Maybe a video type mismatch. Some reason your TV does not like it. I see this about every 2 years. Try a different TV or computer monitor. There is a V.Mode button on the remote that cycles through the different modes. press it wait like 10 seconds press again, rinse and repeat. It will go through several video modes. I would try a different TV/monitor and/or HDMI cable first. The cables that ship with the unit, may for some reason not like your TV.
