So much for updating on your terms.Update- While AW was on charge it updated to wOS 10 automatically last night.
As more "features" are added, the menus required to access them must expand, deepen and be reordered.I really don't understand why OS makers do stuff like this.
Hopefully they fixed some of the awkwardness in some of the apps without breaking stuff that works fine.They've already released 10.0.1 today.
Ultra 2 is on my wrist!
Has a little trouble doing the setup with Verizon. My normal bill was $127/mo After adding the Ultra 2, Verizon claims my new monthly will be $297.
Only thing I can think of is they added protection insurance to all my 2 iphones and 3 Apple watches. I did not select that. Now I have to see if I can get that reversed. I may be forced to go to the Verizon store.
Anyway, aside from the huge increase to my bill the watch itself is obviously faster than my AW6. The resolution of the screen is noticeably higher and brighter. Only one of my watch face setups was added so I may need to do the others manually. Lots of app details needed to be added.
That's what I was thinking but it's no big deal. Had to reapprove the wallet cards but Apple Card was automatic. Most of the apps data was transferred over. Only the custom faces I need to set up now.You should have been able to restore a backup from your old watch to the new one. Select Customize settings during the pairing process and you should be able to select which backup to use.
A little research and I discovered all my original faces are there. The Ultra 2 has a different process to switch. I have to go into edit and then swipe left or right to see and select them. Never needed to go into edit face before.Only the custom faces I need to set up now.
That's quite a manacle.Got the new Titanium watch band in today.
