AMIKO Amiko MINI 4K UHD S2X - V1.0.69 Firmware
Hyper Casey
327
579
Mi
V1.0.69 Factory Firmware updates:
- Allows the User to Manually Set the Symbol Rate of a Transponder as low as 100. (See attached pdf "Low Symbol Rate Radio Services" - thanks to comfortably_numb)
- **The technical staff of the Demodulator said that the minimum should be greater than 200, and the locking will be relatively slow.**
This has the new V1.0.69 firmware plus has my custom Sat/TP list covering 15.0W to 137.0W.
Load using "All SW + bootloader"
USE AT YOUR OWN RISK of course, and if you dont know what you are doing, please ask, and we can provide more instruction before you try to upgrade.
By loading this file, you will wipe out all of your channels. You will have to re-scan everything because some sats were added, some sats edited, and sat position numbers changed etc... *Use at your own risk. Back-up your existing Sat/TP/CH list just in case.
Also, there is a 2nd download. This is the exact same as the first but adds the Mood (Muzak) "hidden" radio music channels on SES 101.0W Ku. These usually require manually entry one by one, but i have done the work for you. You are welcome!
This download will give you a new updated firmware V1.0.69, plus the custom Sat/TP list, plus add the Muzak radio channels on SES1 Ku.
*This is for the Amiko MINI 4K UHD S2X FTA Receiver only.*
Please test and post results. I do not have Ku Band, so i can not test this myself.
For the Muzak Channels on 101.0W
After loading the file and after the receiver re-boots, go to
< Menu
< System
< Default Setting
< Save Default Value, Hit OK to Save
This will save the 101W Muzak channels as default, in case you want to start over the channel list at some point, these will not get wiped out.
Reactions: mc6809e and TRG
Edision Raed Quick Signal Plugin
AMIKO Amiko MINI HD265 - V1.6.06 Firmware
