I'm going to say yes. I know you can get composite video and analog audio to HDMI for under $25 from Amazon and other sources.Is there a device that can convert composite video and optical audio into HDMI?
DMCA criminalizes the reproduction of anything that has DRM, as well as making available technologies that support it. The content need not be formally copyrighted.Does this mean holosuite recordings will be DRM protected?
I think we all understand what you're asking. The problem is your TOSLINK requirement, as I made clear in post #3.I am not sure you all understand what I am asking.
I am trying to watch LaserDisc movies with DTS,DD, etc and want to pass them through my surround sound. My surround sound only takes HDMI and Toslink inputs, no RCA inputs.I think we all understand what you're asking. The problem is your TOSLINK requirement, as I made clear in post #3.
It is entirely possible that the most cost-effective method is to use an older AVR that features RCA video and TOSLINK inputs as well as the ability to upscale the composite video (this is going to be a stinker). There's a relatively narrow time window where all the necessary inputs and outputs were present and could be used together with upscaling.
As is often the case with such queries, you would get more thoughtful responses (or better alternatives) if you started at the beginning and told us what you are trying to accomplish, rather than somewhere in the middle where your theory hit an apparent dead end. Begin your query by identifying the source media origin.
As an example, state that you have some movies on LaserDisc, DVD, or another format with more than two-channel audio, and you want to show them on an HDMI system with multi-channel audio retained.
Which LaserDisc player do you have? I have the DVL-909 and it outputs digital audio via Coax and TOSlink. My Denon accepts four PCM sources, two Coax and two TOSlink.I am trying to watch LaserDisc movies with DTS,DD, etc and want to pass them through my surround sound. My surround sound only takes HDMI and Toslink inputs, no RCA inputs.
Every Laser Disc player I owned ( back in the day) had, at least, TOSLINK outputs.Which LaserDisc player do you have? I have the DVL-909 and it outputs digital audio via Coax and TOSlink. My Denon accepts four PCM sources, two Coax and two TOSlink.
My Denon does not accept RCA inputs, that is the issue, hence wanting to combine both TOSlink and RCA into HDMI.Which LaserDisc player do you have? I have the DVL-909 and it outputs digital audio via Coax and TOSlink. My Denon accepts four PCM sources, two Coax and two TOSlink.
Something like this adapter would allow the coaxial Digital output from your LD Player to connect to your Denon's TOSlink input:My Denon does not accept RCA inputs, that is the issue, hence wanting to combine both TOSlink and RCA into HDMI.
If you believe the legends on the ports (and I do, since the port that looks like an HDMI output is so small as to be a micro USB), this device only converts between digital input formats (coax to optical or vice versa). As noted in the OP, the LD Player already features an optical output.Something like this adapter would allow the coaxial Digital output from your LD Player to connect to your Denon's TOSlink input:
The problem with this line of reasoning is that they have to be glued back together in a lip-synced manner, and that's nearly impossible without an integrated solution.But, the point of treating the Video HDMi conversion separately from the Audio would be more affordable. ~$30 for the Video converter and just program the Denon AVR receiver to use HDMI channel "x" with Digital Audio input "y" for LaserDisc.
By Steve 2/18/2026
I'm no expert, but this thing seems to be designed to use the component input, with composite an afterthought.
With composite, my unit displays a terrible, blocky image, as if it's using 1/2 or 1/3 of the resolution, and being an interlaced signal, it may be just half of that. Really bad. When I had the chance to test it with a component signal, I got a nice picture. So it's of limited use to me, and so disappointing that I don't trust Black Box at all.
Since video processing would be entirely independent of audio processing (both of which usually take time, especially when affordable gear is involved), this isn't the same as your setup, which was designed explicitly to bring everything together.I never saw any lip-synch issues between my Denon's different inputs pulling audio from the digital input, but my AVR-X3400H is old enough to do the analog video upscaling internally.
