New Slimline Dish
urnote96
156
In our meeting this morning, there is a memo sent down from Directv about the WNC new slimline dishes, I guess the first 17000 of these dishes, you will get a SFSS (searching for satellite signal) if you do not have WB68 hooked up. So anyone in the future that does not have a REV 1 OR REV B on their LNB (SLIMLINE) will get this unless they hook up the WB68.
So no matter how many RCVRS you have you need a WB68 on these 17000 dishes....
What is a WB68?
What is a WB68?
The difference being, you would normally only need the multiswitch if you were using more than 4 line coming in, appearantly, there is a problem somewhere that is requiring you to use the multiswitch regardless , if this quote is correct.
Jimbo
I dont have a scanner so i will type what it says
"The WNC (Wistron) Slimline Intergrated KA/KU lNB's Model AU9 S/N ALL, excluding "REV.1 or REV B" REQUIRES A 6 * 8 WIDEBAND MULTISWITCH ON ALL INSTALLS, REGARDLESS OF THE NUMBER OF OUTLERS. This will insure all IRD's receiver the proper signal. THIS APPLIES ONLY TO WNC (WISTRON) NO OTHER MANUFACTURERS
There were approximately 17,000 units shipped.
Future versions of this LNB will not need the 6*8 wideband multi-switch. They will be labeled as "REV 1" or "REV B" to the of the S/N Bar code.
Forunatly (I think) I have a Cal 5 LNB, so I am presuming the trouble is ONLY with the WNC dishes
