Hi-
Just spend the day installing my new Star Choice dish. What fun!
Damn big dish. Unfortunately the mounting pipe is wider than the ExpressVu I am replacing, and the mounting plate is pretty tall (8.5 inches) making it hard to find a spot where all four screw holes are secure. But anyway...
I was fairly confident I had the right azimuth, elevation and skew (I used the KuSat calculator) but I'm only able to get 50% signal strength (I'm in the Canadian colony of San Francisco). The weird bit -- I realized the LNBF arm was loose (meaning the arm was pointing down a bit). When I tightened it (meaning the LNBFs were higher), I lost signal entirely.
A couple of questions:
- Which is the more forgiving measure, skew or elevation? Given the LNBF arm issue, is one a more likely culprit?
- What's the minimum signal strength required? (I have a 505, but it's not activated yet.)
- What's the diag C / option 6-0-5 equivalent on the 505 so I can check the EB #?
- The signal strength meter says satellite "A4" -- could I somehow be pointed at the wrong bird entirely? Should I be able to see two, or does only one get listed?
Thanks.
johnny0
Thanks.
johnny0
