Has anyone tried to convert a Primestar dish into a Dish 1000? What I want to do is use a spare Primestar dish that I have and find a way to mount the 3 lnbs on it so that I can use that for 110, 119 and 129. Any ideas? Thanks in advance!
You could mount a single LNBF and point it at the 129 satellite for probably pretty good gain. Might help give a little more time before rain fade is a factor.
The LNB should be easy to mount - just take off the outer shell, and I bet it would fit into the existing Primestar mount - Then, I could just run a cable over to the 110/119 lnb from the "new" 129 Primestar. Hmmm..... Might have to give it a shot!
I can see some possibilitiesTHANKS!
Spend 99.00 and get a dish1000.2 from either the dishstore.net or dishdepot.com. It is much easier than trying to retrofit a Primestar dish. I looked at my old primestar dish and there is no way to adjust the skew at all , to what it needs to be to get all 3 sats. It only adjusts by elevation.
OKay I stand corrected. If you want to do all that to use a Primestar dish then go right ahead. I would rather save my time and just install a ready made dish 1000.2 .
