36" dish for directv?
Jim "Spot" Beam
96
Southern Ohio
Currently have the 3 lnb, spare 36" dish, and snow beyond belief.
Can I slap the 3 lnb on the larger dish to avoid snow/rain fade?
OR...
Should I just go read a book?
IMHO, if the snow is going to build up on the dish or LNB's it's still going to do it with a larger dish. What I'd recommend instead is a dish heater that you can turn on to melt the stuff off.
If you can see the dish any chance you can get a hose out and shoot water up there to clear it off? That's what I used to do before I put the dish on a ground mount.
About to say, why not take preemptive measures during late summer/early fall and employ some covering or water/ice/snow resistant mechanism/coating/device seeing that it must snow there regularly each season?
Problem here is that no one has been able to find a product thatb will work consistantly, there have been a wide number of products tried and none have worked everytime.
I personally have thought about the dish heaters and think that would be the only real way to go. Only trouble with that is, it goes on with a thermostat type device and I would rather it be on a switch that I can turn on and off when I need it, iinstead of it going on and staying on when it's under 30* or whatever temp it is set at.
Jimbo
What about a snow cover; my in-laws in STL use one without fail.
I could try one, not sure what the covers cost anymore, I would need a 3 lnb and a 5 lnb one.
I should look around and see if I can find them, last time I checked, the 5 lnb was not available.
Jimbo
Yep since the 5LNB is relatively new, covers have yet to catch up, I read many users are using a trash bag method in the interim. You could always call one of them and inquire directly about one for the 5LNB dish. Help facilitate a new , needed item for your snow covered buddies. http://www.montanasatellite.com/satellite_dish_covers.htm
Ahh, a quick search says the above company is already selling them; both the original and SlimLine.
Don't they make an oversized dish for Alaska? I thought I saw on in some supplier's catalog recently.
i go with the flame thrower idea. make some money going house to house, "may I torch your dish for you?"
HR10-250 KAKU Dish
HR10-250 Question
