D 500 Legacy Twin to 322
Davevh@comcast.net
18
Las Cruces NM
I am using a D 500 Legacy Twin with two cables going to a 322. Is there a way to run one cable?
I plan on adding a 3900 later. can I do this using the same dish?
I am amazed at the well informed answers given in this forum.
Aint free will and interprise great?
Nope. No way will that LNB work. You'll have to swap it out for a DP+ Twin. That's the only way you'll be able to power up both receivers with a single feed for each. Keep in mind, for the 322, you'll also need a DP Separator. That will allow both Tuner #1 and Tuner #2 to work properly
You could upgrade to a Dish Pro Plus Twin or upgrade to a Legacy quad. Your Legacy Twin is maxed out with 2 tuners running off it.
Will a plain Jane DP Twin be good enogh?
A 123254 separator came with the reciever. Is it the right one?
Any advice is welcome.
Nope, DP Twin and DP+ Twin are two different technologies. Only the DP+ equipment allows the bandstacking required to support the dual-tuner receivers over a single coax through the seperator.
100.2 Dish
Cricket PPV on multiple receivers
