Any review on "US Electronics Legacy" receiver?
Can anybody tell me about the "US Electronics Legacy C/KU IRD C-Band Satellite Receiver?" I hear it's an oldie but GOODIE.
I just bought a new one, sealed in the box for $35 total on eBay, I thought it would be good for the 10' dish I'm getting. Here's the specs, tell me what you think....please?
100 Priotity-View Program Memories
50 Satellite Memory Capacity
Actuator Power - 36 Volts DC @ 3 amps max
Actuator Sensor Pulse Type Interface Reed switch, Hall Effect or Optoisolator devide
Adjustable Audio Bandwidth Filters 5.0 to 8.5 MHZ subcarriers in 120 KHz, 300 KHz or 600 KHz bandwidth
Auto Sat Locate System
Automatic Operation on C and KU Bands
Automatic Peaking Antenna Tuning
Digital Stereo from Descramble RCA Outputs
Dual Audio and Video RCA Outputs
Extended Threshold Circuitry
Extensive On-Screen Set-Up and Program Menus
Internal Power Supply / Actuator Control
Parental Control Lockout
Polarity Control Servo Type Polarizer
Power 108 to 132 volts AC @ 60 Hz
Remote Control Direct Channel Access / Direct Satellite Access
Separate "C" Band and "KU" Band LNB Inputs
Sockets equipped for use of customer supplied Videocipher 2 Plus descrambler module
UHF Remote
UHF Remote
R.F. Section
INPUT I.F. 950 to 1450 MHz
INPUT LEVEL -60 to -25 dBm
NOISE FIGURE 12 db Maximum
SECOND I.F. BANDWIDTH 27 MHz
SECOND I.F. Frequency 140 MHz (loop provided)
THRESHOLD less than 7 db C/N
Video Section
Outputs Composite, Filtered an Clamped
Output Levels 1.0 volts peak-to-peak nominal @75 ohms
Video Section
