"Move address"
lzqwhr
Mar 21, 2006
5
Michigan
Added question that I have....
I'll add a question to this instead of a new thread;
I called the CSR nad had them change my 'service address' to a town near me that carries my desired local channels.
Now. do I have to do anything on my side? Turn off receiver for x amount of minutes? Change anything in the Dish Menu? How long will it take before I see my new locals?
cebbigh
1,601
Frostbite Falls
I've tried doing it 3x and all that has happened each time is I lost the guide info for the existing locals. I'd like to know what I'm doing wrong.
Voyager6
*Cancelled*
17,097
5,324
Wokeville
Are the locals that you are trying to receive on a spotbeam that you can receive?
Kaydigi
487
Sometimes during the move the CSR doesn't add the new locals even though they say they do.
Hall
18,409
3,200
Germantown OH
Do you mean you lose the locals for the city that you "used" to live in before you "moved" ?? If so, you're doing nothing wrong. That's the way it is. You can't get locals for (2) cities. As also mentioned, you have to move to a city whose locals broadcast off of a satellite that you see.
cebbigh
1,601
Frostbite Falls
I know I should loose the guide info for the locals from Dish. But aren't you supposed to keep the OTA guide listings?
Both Chicago and LA are on 129 and not spotbeams. I do see good signal on the respective TPs.
Peter Parker
Formerly Geronimo
12,445
2,219
The HD LA locals are on 129. The Sd ones are at 119. Which are you trying to receive? Is it possible that you don't have them mapped down correctly in your 622?
n0qcu
5,220
2,139
Earth
IF dish would write the software the way they should but since they don't you only get OTA guide info for "your" dish locals.
Peter Parker
Formerly Geronimo
12,445
2,219
Perhaps I read this wrong. i thought that you could not see the locals . it seems that you a re complaining about guide data not the locals. My mistake.
cebbigh
1,601
Frostbite Falls
What I was attempting to do was receive the HD locals from dish for either LA or Chicago or anyplace else that Dish transmits the FOX HD local. Dish and Tribune have been locked up for 1 year in coming to terms for the retrans of the Fox HD signal in Seattle. The signal for FOX (KCPQ OTA) is very hard for me to pick up consistently.
I'd be very happy to just get the signal from some other city but still need to get the OTA guide info for KCPQ OTA to facilitate recording Seahawks and other NFL games.
That's more info than anyone probably wanted to know. I just can't figure out why when I have attempted to move it doesn't work for me but seems to have worked without any hassle for others. There has to be a reason. I had just decided to to let it ride until FIOS becomes a reality (guestimate=1 year) but then 4.03 came and the OTA signal for KCPQ degraded (oddly while all the others improved).
poppasnoop
Apr 6, 2007
30
I am new to all this. Could someone explain in simple detail how a person currently in Providence, RI for example, could get the locals (including HD) from nearby Boston, MA, for example. Many thanks!
Hall
18,409
3,200
Germantown OH
Tell them you've moved to Boston and give them an address for their. Explain that this is your *service* address and that your bills need to continue going to the current address.... Your parents still live there and they pay the bills.... (doesn't matter but if they send your bills to this new, bogus address, you'll have problems). Or, switch to electronic billing so there is no paper bills.
DWS44
7,446
4,682
Rock Hill, SC
Interestingly enough, I assumed I would lose the guide data for my OTA locals when I moved, however that wasnt the case at all. On the 622 I have the satelitte "locals" from my service addy, and still have the guide data for the local OTA as well. Was a nice surprise!
Kaydigi
487
So the next step is just call them and say you don't see the locals? After that does the OTA guide just reappear?
Yes. I signed up for NYC locals and it wasn't added during the initial move call. I called back and another CSR added it.
I have E* HD locals and still my Richmond,VA OTA locals with correct guide data.
Outstanding Customer Service
Howdy from Team Summit
