pivot bolt & elevation bracket pictures
Pivot Bolt:
Here is a bolt I was suggesting.
Note the unthreaded portion by the head is bigger than the threads.
You don't want the kind where the threads are bigger than the shaft.
Use is described in the posts above.
Elevation Mod:
As for where to put the jack-screw to pull the dish to a higher elevation, as I described above, here is a picture of the bracket required.
Sorry for the lousy drawing - I used PAINT
You'd need to drill through the vertical support at the red circle, on both sides.
Then, you'd need to use a little file and square up the hole on the dish-side.
That would prevent the carriage bolt from turning.
The green line represents the carriage bolt.
It goes through the yellow bracket, and by tightening a nut on the end of the bolt, the dish is brought up to a higher elevation.
Well, that was my idea.
I thought even a poor picture was better than a lot of words.
