Team Summit General Assembly Notes
ONce it is out of someones mouth you can't retract it- especially when you are the Ceo of the company. What is the big deal. It actualy sounds like that Dish has a plan to not only compete with cable and Directv the turd bird ,but to pass them up with more hd and possibly better picture quality using mpeg 4.
So, does this TR40 receiver only receive OTA HDTV (8VSB)? Or does it also receive QAM? And can it receive / subscribe to any Dish Network services?
No, it cannot receive Dish services. To qualify for the $40 coupon, it must be an OTA only receiver, with only an antenna input, and no HD output.
Also, where does this MPEG 2 > MPEG 4 transition leave Sky Angel?
Just where they are today. At 61.5 in MPEG-2. And they'll stay that way. Anybody know when that agreement/settlement expires? And anybody want to hazard a guess as to if Sky Angel will still be in business by that time?
The photos Scott took of the TR-40 (almost half of a TRS-80;)) show it has composite output in addition to the RF out. Too bad id doesn't have S-Video, though, as ATSC has such nice colors and chroma-crawl will probably be fierce! It is interseting to note that there appear to be three RCA-sized connectors covered by plugs. I wonder if there won't be a version of this box that has Component-out for HD-Ready sets?
Composite is fine. No HD there.
The government has a list of forbidden features on these converter boxes, features that if present will make it ineligible for the $40 coupon. The links are posted elsewhere.
But maybe they could sell the component enabled boxes separately.
After I looked at the picture some more, it may be that the RCA header the Dish uses in manufacturing its receivers has those R-G-B RCA jacks closest to the circuit board. It's probably cheaper to source the one part (and put covers over the unused jacks) than it is to buy a limited number of the R-W-Y-only RCA headers.
Come October we want you to address Directv by their new name.Directv the king of everything that is HD.:D
I am willing to bet that DirecTV won't have more theb 50 national HD channels (part time ones don't count)
Of course I don't expect dish to have that many eaither.
Its all just marketing hype. DirecTV has been talking about 100 hd channels for 2 years now.
While Dish has not publiclly advertised any number of HD channels for the future.
I think no matter what company your with more HD is coming and that's not a bad thing.
The key item that stuck out was:
On these two Satellites they will be relaunching Dish Network in FULL MPEG4. All current Dish Network Channels will be available in full MPEG4. And everything will be receivable with just one 18 inch dish.
This is pretty much saying that the satellite(s) have to be on the Ku-DBS band since a larger dish would be required on a Ku-FSS or the KA band.
Just speculation based on the above would suggest that a new slot would be used and 2 satellites launched to it.
E11 is supposed to be a spot beam satellite with steerable slots. Steerable spots would allow it to go to a variety of locations and still be able to aim the spots at the right cities.
There has been notes of SES building a Ku-DBS satellite for Dish with a TBA slot (mentions in Dish's SEC filings).
So, if the SES satellite is CONUS Ku-DBS and E11 is a spot beam satellite that can go in a variety of slots, it is possible they are going to a new slot. Either a foreign slot (like 129 is Canada and 77 is Mexico). Or perhaps a new slot that the FCC is going to open up (although you would think there would be more public announcements out of the FCC about this).
With CONUS from SES, spots from E11, 8PSK and MPEG-4 they could have a single satellite location with 2x+ the capacity of a old technology slot.
When they say 1000 standard definition channels, I believe they are counting the channels on spot beams.
I also wonder about national HD content, if that would require a second satellite location. To serve 200 cities with SD locals and 100 cities with HD locals, that would take a lot of spot beams. This means that they would probably have to have a bunch of transponders used for spot beams to cover all this. One would almost have to have 10-15 TPs just for locals. This would leave 17-22 TPs for CONUS. 17TPs * 25channels/TP is 425 channels of standard definition CONUS not allowing for any CONUS HD.
This is of course all speculation. Other alternatives could be a combination of KU-DBS and Ku-AUX which Dish has licences for too, perhaps they could come up with a slot that uses 32 Ku-DBS and 16 Ku-Aux TPs, for a small dish to work they would have to have 4 degrees of separation from adjacent slots... This would let them do something like 16 TPs for spots, 16 TPs for 400 standard def CONUS and 16 TPs for HD (64-96 CONUS HD channels).
It would seem to me that they would want to keep these new birds at or near the main 110/119 slots. IF the Dish500 can be used for 119/129, then E* could:
1) convert all content at 129 to MPEG4
2) move the bulk of SD to 110
3) remainder of SD and MPEG4 at 119
There are several assumptions with the above, but with a new bird at 129 the weak transponder issues go away. Parking the other one at 119 gives all the new MPEG4 goodness to 119/129 which should be the lesser issue for repointing customers. Legacy customers do not need to be repointed.
What this doesn't take into account are the spotbeam issues, capacity issues, etc. If those can be managed, it seems like E* has to work with 110/119/129 to implement this new plan at minimal cost to them (repoints, etc).
Now, all you technical gurus can point out the error of my ways for thinking this! :D
(please be gentle ;))
Red
The plan is to create a mirrored service for mpeg 4 and then transition everyone over to mpeg 4 receivers and then repoint the dishes or reissue the new 18" dish and lnb for the new mpeg 4 sat locations.
I imagine they will slowly start turning off the mpeg 2 customers by programming. First the mpeg 2 hd channels will go off . Then the premium movie customers will be upgraded and then they will cut off the basic programming . Somewhere in there they will have to upgrade all international customers unless they want to remain just international wing dish customers.
I think it would behoove DISH to cut down all receivers to just a few mpeg 4 ones and sell the old mpeg 2 receivers to their sister service in Canada : Expressvu. Since they use the same receivers that Dish uses and they just change the faceplate and model numbers and software. I also imagine that there will be a whole lot of sat dishes to replace over the next few years to be able to go all mpeg 4.
I hope that DISH plans to offer some great upgrades to get existing subs to upgrade and that they effectively COMMUNICATE to them about the pending changes or instead of retaining existing subs, they will be losing them due to the changes. This is as big a change as when Primestar was bought by Directv. There needs to be a lot of press either by mail inserts, dvr events downloaded to the hard drive , phone calls ,etc.
I think the addition of the Alaska and Hawaii HD markets has something to do with the law. I believe that both DirecTV and Dish Network must provide the digital locals and all of their digital subchannels to the non-contiguous states by June.
The two satellites for the new MPEG4 service are 10.5? apart. I could see Dish reusing a customer's Dish 500 or Dish 1000 with a new "Y" adapter with the proper spacing. I assume that Echostar owns all the transponder licenses for these two new locations?
RedSavina:
I doubt there are enough frequencies at 110/119 to do all that. If there were more available frequencies there, I imagine they would have put up more/bigger satellites already.
Yeah to early say how they will work things so we will all half to wait later in the year see how things go.
622 external harddrive question
322 receiver, TV1 UHF Pro?
