New Hughesnet .74 dish hardware
mikeroberson2006
69
Anyone else having problems with the new hughesnet .74 dish and tightening the azimuth bolts with the new hardware. Is Hughesnet working on this problem and if not, how can we get them to work on this problem?
If the bolts just had more shoulder depth they would work fine. As they are they are a real PAIN! I use needle nose pliers to hold the head in and curse the whole time.
Is this the dish?
Yeah thats it. Yesterday i figured a way around it. I took the nuts off of the azimuth bolts and switched them for other nuts/lock washers in the bolt pack, much easier now.
An easy fix for this... just put the elevation up high enough so you can use a ratchet and snug the bolts just so they are seated. Put elevation back to where it should be, tune as usual, and they will not spin.
On another note about this pos dish............. do not try to replace the tx without taking the dish down. It is so wimpy that it will bend the area where the arm meets the dish if you are not VERY careful. Had it happen to me on a hard to reach one and it bent, changing the focal point to where it would not work. :mad:
I know hughes is trying to compete with WB, but I think they would be better off trying to be the BEST and not the Cheapest. Do you want a Cadillac or a Hugo? :rolleyes:
what do you think of the larger dish offered by Hughes for the small business services. It is supposed to have a .98 m Antenna & 2 W Radio, compared to the "residential" equipment of 74 m Antenna &
1 W Radio. Will I see a noticeable difference or a waste of money? The FAP is also different in the residential vs business. Any comments out there would be greatly appreciated.
J & W in Alabama
J & W in Alabama
The biggest difference you will see will be in the upload speeds. Also if you plan to be very active on it "working from home" I would recommend you go with the small office plan. I you do not want to go with the small office right away you can still upgrade your initial install to the .98 with 2 watt unit so you would have it in case you might upgrade in the future. That would be what I would probably do in your situation.
Anyone with Bellsouth DSL?
Starband 129 alignment pc software
