02468 no longer works!!!
$735.00
baba_ghanoush
Close
Why can I not force download new firmware since doing so a couple of months ago??? I've tried numerous times on Saturday nights between 11-2am EST :confused:
Do it a key at a time.. i do it slow and works fine everytime.
Sent from my SPH-D710 using Tapatalk
This is a repeat of the message I put in the HR2x/H21-H25 CE Release 2/10 thread
If your remote is set to RF,a lot of times it will give you fits trying to type in 02468. The RC64RB universal RF/IR remote(used to operate my H24 in RF) can be a real PITA when it comes to typing in 02468 & it's set to RF. I have to go through the trouble of converting it from RF to IR,type in 02468,download the CE,& then convert back to RF. The newer RC65RB universal RF/IR remote(used to operate my H25 in RF) is MUCH BETTER operating in RF mode with no hassle.
Works fine for me. On my HR24 i have to start entering in the second the blue lights come on after the restart or it doesn't take.
Works fine for me. If running through a receiver, you need to watch the lights on the receiver and not wait for the picture to show up on the screen.
S~
Well the flying,fickle finger of fate came to visit me last Friday night when I tried to D/L this weeks CE on my H24. It didn't matter if I used IR,RF or even changed out remotes,my H24 was not going to accept 0-2-4-6-8. When you punch in the numbers,you can see the light on your receiver flicker. Well it wouldn't flicker when I punched in 8 or 6 then 8. I rebooted,unplugged the power cable & replugged it in,my H24 was not going to accept the 0-2-4-6-8 code. I just gave it a rest & downloaded the CE to my other DVR's/receiver without any problems. I'll just try again this upcoming weekend & see if my H24 behaves this time. No other problems with the box,just a PITA to download CE's(maybe it liked the previous CE so much that it just didn't want to give it up).
Now both my H24 & H25 are refusing to take the 0-2-4-6-8 code. They both refuse to take the 8,& then when I try again,they refuse to take both the 6 & the 8. I have no problems with my DVR's,just with the HD receivers now. What this means is that until the latest/future national release comes around,they are both stuck on the CE's that they each last downloaded.
I was having problems getting the code to work on my HR22 too, but I finally just took my time, entered the code only once, and started entering it as soon as the blue lights started to move. I also entered the code with the remote in RF mode. Hopefully that works for you.
HR34 is a PITA, timing is different than other models.
Yup RF remotes are the best, fresh batteries for the remotes for those with problems?
The remotes I use are paired,HR24(which takes the 02468 code without problems) & H25(which started having problems last night) paired together,& HR23(which takes the 02468 code without problems) & H24(which still has problems). I could try new batteries. My HD DVR's behave themselves,it's the HD receivers that can be a real PITA.
Well I changed the batteries in both of my remotes & I was able to download the latest CE's to my H24 & H25. I still had to change my H24 from RF to IR to download the CE & then revert back to RF.
Finally Activated Whole Home
My experience with the 0544 software on my HR34
