1000.2 (EA)
allenmc_ SUI
17
Today I got my first supply of .2 ea and tried to use 1. Fist someone told me the settings where the same as a .4 that is not true it differs a little but then while siteing it in I caught signal on 61.5 then checked on 72.7 and had it as well. I then ran a lim scan and found I was missing a lot of transponders on both sats. I'm right in thinking the .2 ea and .4 ea hit the same exact thing right other than 77
TheKrell said:
I vote "Yes". Don't know why you should be missing transponders. What does a "lim scan" mean?"
U run a limite scan on the supper/sat buddy it test certain transponders on each sat like 61.5 it checks trans 15 17 I think 20 or 21 but it shows the signal on each and if ur missing the important ones u will be missing channels
When was the last time you updated your Sat Buddy? My wag is that it's out of date on the transponder list. Dish changes characteristics fairly often. The "limited scan" might not waste time checking for all possibilities if it can't lock on right away.
Limit scan checks four transponders on each orbital location, the same four that are checked on the STB Health. What varies is the minimum signal strength as it is dependent on your location (zip code).
Does 2 hoppers mean 2 EHD's?
Why no NCAA Matrix Channel?
