"1000 (DTV) is currently not available"
carlos31820
28
I keep getting this message while trying to access OnDemand. It's worked fine in the past. Resetting my HR21 receiver did not fix the issue. Is anyone else getting this message?
How is your HR21 connected to the net? Are you sure that connection is still "hot"?
When you reset the DVR did you go back in the it's network setup and check the IP address and make sure it was connected?
Are you setup with dynamic or static IP assignment on your router setup?
Well, as misteriously as it began, the issue ended. My OnDemand menu is now working even though I didn't do anything but wait.
Havent had another issue but for the benefit of anyone else finding this thread in the future, my connection is not wireless. I have cat-5 cables inside the walls running from my media cabinet over to a network switch in a separate room.
..and I would add to anyone looking to do what Carlos did (and I have done) look into CAT6 or CAT6a if you do an in-wall cable run.
Help!
Beginning 5/11/08 No more 24/7 CSRs
