101 D* and 110 E* on a D500
RandallA
10,556
68
San Francisco Bay Area
I would like to know if this can be done. I want to use a D500 to get 101 for Directv and 110 for Dish Network. I will use E*'s LNBs, Legacy Dual for 101 and a DP Dual for 110 so LNBs are not a problem. I'm currently using the Legacy Dual for 101 and it works great.
The 9 degrees separation shouldn't be a problem either. My question is more about the skew angle that I would need to see both 101 and 110 on a D500.
My skew angle for E*'s 119 and 110 is 80. When I enter the information for a 2 LNB in the Directv receiver I get 106. Am I to assume that I should set the skew angle at 74 to see both 101 and 110? I would think that the skew needs to be higher because for my zipcode 101 is at an elevation angle of 41 and 110 is at 44. For E* the elevation angle for 119 is 46 and for 110 is 45.
Fwiw, I did do the same thing at one time and it worked with no major issue that could not be overcome.
The only problem I had was because of my location, 110/119 was at the end of the skew position and I had to remove the 4 bolts holding the Dish on and mount the Dish 90 degrees off where it was expected to be - so I could get past the bolts to where I needed to set the skew for optimum performance - thus the skew setting engraved on the dish itself was inaccurate but 101/110 did work as expected after that. For obvious reasons, you cannot use the E* lnb for D* 110 SAT C, as you already know.
As Iceberg said, use the Sadoun link, set sat for 105.5.
However, when you take the skew from 90, he means start at 90.
90 = 0.
If its +20.5, then it would be 90 + 20.5 = 110.5.
If its -20.5, then it would be 90 - 20.5 = 69.5.
Project completed. Thanks Iceberg, you da' man.
It was a pain in the a$$ trying to get it done with the D* receiver. I then switched to the E* receiver and got them both in 5 minutes. The D* receiver will show signal for A, B, C and I only had one LNB, WTF? Anyways, got it done and the skew was 69.
After I got 110 and 101 on one D500, I aimed the second D500 to 119 and 129. Set the skew at 90 and got pretty good signal on 119 but as we all know 129 is a POS and the signal is not that great, some mid 60s and mid 70s. I had 129 on one D500 and an I bracket before and I used to get mid 70s and mid 80s. Oh well just wanted to experiment a little.
Thanks.
622 with OTA
What is LiL?
