11/11/2009 Uplink Report
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,711
29,479
Newington, CT
Note there was a problem with the Uplink PC and thus the delay in the uplink report.
Sorry for the delay...
SatelliteGuys.US DishNetwork Uplink Activity Report - 11/11/2009 5:42pm - 32 changes
Uplink Comparison Range: 11/11/2009 11:00A - 11/11/2009 05:30P
Channel Additions:
125 - ITV2 [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam[/URL] (NA)
125 - ITV2 [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (NA)
703 - FTVTW [MPEG2 SD] added to Anik F3 118.7W TP 29 ConUS beam[/URL] (NA)
9619 - BTVT [SD TV] added to EchoStar3 61.5W TP 10 ConUS beam (NA)
Channel Removals:
148 - ESPNU (A) removed from EchoStar11 110W TP 09 ConUS beam[/URL]
148 - ESPNU (A) removed from EchoStar3 61.5W TP 20 ConUS beam
220 - DISH (A) removed from EchoStar11 110W TP 03 ConUS beam[/URL]
220 - DISH (A) removed from EchoStar8 77W TP 12 ConUS beam
Channel Package Flag Changes:
5655 - KITV [MPEG4 HD] - Ciel-2 129W TP 16 Spotbeam 55[/URL] changed to Available (H)(Honolulu, HI-ABC)
5663 - KHNL [MPEG4 HD] - Ciel-2 129W TP 16 Spotbeam 55[/URL] changed to Available (H)(Honolulu, HI-NBC)
5667 - KHON [MPEG4 HD] - Ciel-2 129W TP 16 Spotbeam 55[/URL] changed to Available (H)(Honolulu, HI-FOX)
5674 - KHET [MPEG4 HD] - Ciel-2 129W TP 16 Spotbeam 55[/URL] changed to Available (H)(Honolulu, HI-PBS)
186 - NTGEO [MPEG2 SD] - EchoStar11 110W TP 11 ConUS beam[/URL] changed package flags (A)
186 - NTGEO [MPEG4 SD] - Nimiq5 72.7W TP 01 ConUS beam[/URL] changed package flags (A)
203 - BITV [MPEG2 SD] - EchoStar11 110W TP 02 ConUS beam[/URL] changed package flags (A)
203 - BITV [MPEG4 SD] - Nimiq5 72.7W TP 23 ConUS beam[/URL] changed package flags (A)
233 - NOTAX [MPEG2 SD] - EchoStar11 110W TP 01 ConUS beam[/URL] changed to Not Available
233 - NOTAX [MPEG4 SD] - EchoStar8 77W TP 12 ConUS beam changed to Not Available
597 - RCORD [MPEG2 SD] - EchoStar3 61.5W TP 18 ConUS beam changed package flags (A)
735 - TRACE [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam[/URL] changed package flags (A)
751 - AFROM [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam[/URL] changed package flags (A)
792 - JAYA [MPEG2 SD] - Anik F3 118.7W TP 06 ConUS beam[/URL] changed to Available
809 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam[/URL] changed to hidden from non-subs (A) (H)
815 - RCORD [MPEG2 SD] - Anik F3 118.7W TP 30 ConUS beam[/URL] changed package flags (A)
19029 - BITVV [DATA] - EchoStar11 110W TP 02 ConUS beam[/URL] changed package flags (A)
Channel Type Changes:
5862 - SPEC1 Anik F3 118.7W TP 32 ConUS beam[/URL] changed from SD TV to MPEG2 SD (NA)
Channel Renames:
5659 - KFVE - Ciel-2 129W TP 16 Spotbeam 55[/URL] renamed to KGMB (A) (H)(Honolulu, HI-MY)
5671 - KGMB - Ciel-2 129W TP 16 Spotbeam 55[/URL] renamed to KFVE (A) (H)(Honolulu, HI-CBS)
604 - KINO - Echostar12 61.5W TP 21 ConUS beam[/URL] renamed to KINOE (A) (H)
737 - KINO - Anik F3 118.7W TP 26 ConUS beam[/URL] renamed to KINOE (A)
9645(99) - SKIN - EchoStar11 110W TP 10 ConUS beam[/URL] renamed to ITV (A)
9645(99) - SKIN - EchoStar8 77W TP 29 ConUS beam renamed to ITV (A)
Channels in the system: 6627
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Is Hawaii the first market to get PBS in HD? Does anywhere have MYTV in HD?
In Denver, MyTV (KTVD 20) was activated over the summer. This was done because the NBC affiliate (KUSA 9) owns the MyTV station and runs their newscasts in HD on that channel at 9 PM Mountain Time.The also run Denver Bronco games which air on ESPN or NFL Network so not to pre-empt NBC programming. As for PBS, there are some smaller markets (abput six or so) which their PBS station was uplinked in HD.
Looks like 2 new channels. 186- NTGEO & 203- BITV
I see that 203- BITV was put up, but I am not getting that channel for some reason. Odd?
I am getting 186- NTGEO. Looks good.
I think u r smoking crack..those channels have been around for a while (However they may be in Free Preview Mode)
Something about this report is off,
Channels 597 and 815 should both now be Hidden from non subs like 809
597+815 were on a one week preview and now that has ended and they are hidden, prior to the preview for the last week they were never hidden from non subs so maybe that is why you didnt catch the change.
There are 4 FTA channels on ciel 2 conus TP 32 in QPSK/MPEG2, one is shopnbc but the other 3 are either asian internationals or ethnic locals from california or something. Been there a couple weeks and no one has mentioned anything, I guess TP32 @ 129 is being used for testing or temp services.
D
11/19/2009 5:19am - Uplink Activity Report - 1 change
Post your 129W Spotbeam Signal Readings
