110 problem on super dish
icunurse
I have a 105 super dish I can not tune in the 110 satellite worth a c-----ola
I am aware of all of the tuning tricks with the dp34 switch but I get a crap signal on 110 mainly around 34....treese are not the problem :) I wish it was
What transponder are you using to get the 34 reading? How are the signal strengths on the 105 & 119 sats? 110 is mostly spotbeams, you may be looking at a spot that is not for your area.
Transponder 11 on 110 usually works pretty well. You should be hitting close to 100% signal if everything is aligned correctly.
Extra Transponder Space
CNN Unveils 1st HDTV Documentary
