2 lines to One
Digital Rain
SatelliteGuys Guru
143
ALBUQUERQUE, NM
Is it poss to connect D*phase III dish having one cable line coming in from the dish and turning it into 2 hook ups for the DVR. IE the same hook up E* has for their DP LNB's/DVR set up's .
Reason I ask is that Im in an apartment and can only get one cable line thu the crack in the door. I have E* now and would like to switch back to D*. ANy help would be great!
And will only work with the HR20 currently H20 and D12 will need software updates before they work. The R15 won't work with it.
For those other receivers, look into the stacker/destacker solution.
Except that solution only works for the 101 satellite.
Could you make the crack bigger? :)
Quick Positive for the HR20
AV Switch for H20 and HR10
