211k run checkswitch every morning
nissan4x4
53
Northwest Arkansas
Hey back with another problem this time hd related, i have a 211k and every morning at eight i turn on the receiver to watch tv.But it always says lost signal, so i run a check switch and it will not find my 1k2 unless i unhook the sat cable. plug it back in and then run a check switch and then everything is good until i have to repeat every morning.And i have ran a new cable to my dish and have a second lnb with same result which makes me believe its the receiver tuner, any thoughts?
thanks Nissan
thanks Nissan
Is this the only receiver that you have? It does sound like it could be the receiver since you have replaced the LNB and the cable.
Have exact same problem! Same receiver ! Checked everything, cable checked, lnb replaced and signal loss. I think its software issue on a receiver.
