3 dishs on roof normal???
Iceberg said:
the issue is Elmira, NY locals are ONLY on 119
SatelliteGuys.US_TheList - Dish Network Elmira, NY
so they would normally set you up with a Western Arc. But since you have tree issues for 129 you should be set up for 61.5/72/77 (for everything else) and a wing dish for 119 (for the locals only)
That would be a much better solution than 3 500's and a 44. Unless the O.P has mpeg2 receivers and the configuration was done prior to the migration change workorders, or the listed orbitals are incorrect for his account.
It was befor the migration and I still had a 301 reciver at the time.
If you have LOS to get 61.5 and 72 on one dish, then you could go to a 1000.4 EA dish with the Dish Pro Plus EA LNB coupled with the Dish 500 for the 119 and 110 sats running back into a DPP 44 switch. That would take care of your HD channels, your local channels, and your 301 receiver.
I don't blame the tech for having you on both 61.5 and 72. You never know when Dish will get the itch again to start moving HD channels around between those two satellites.
Put this up in your front yard. :D
Dish Network University Package
dish pvr drives
