3 LNB to 5 LNB
Mark Dearborn
Oct 13, 2008
I have a DTV dish with 3 lnb's. There is an area for the two other lnb's. Can I put the other two lnb's on this dish (Slimline) and if so, where can I purchase them?
boba
11,350
1,036
Dorchester, TX.
If you already have a Slimline which it sounds like you have there are no more LNBs to add you already have 5. You may need to aim it correctly.
Bob Nielsen
1,721
Bainbridge Island, WA
The 3LNB assembly for the Slimline is much smaller and there isn't any place that looks like it could hold more. The 5 LNB assembly has the 99/101/103 head in the center and the 110 and 119 to one side. The blank space on the other side is either there for symmetry or it holds some of the switching circuitry.
Zynergi
938
NC
There was a 3 lnb kaku out that just removed the horns for 110/119 but kept the same shape, it was quickly redesigned though to remove the "wings" to save money.
run additional coax from at9 - simple way?
Why should I switch to Directv?
