Attempted to dial in an old Dish 500 to 61.5 using a single LNB mounted on the 110 side of the Y adaptor.
I'm in the Portland, OR area so my look angle is only 12 degrees. I've had 61.5 dialed in before when all the HD channels where there, although I was using a Dish 300 then, so I knew that I could get it.
Well... my first attempt failed but then I remembered that some of the early Dish 500s had to be adjusted up 5 degrees to compensate for bad markings on the side. Once I made the adjustment "bingo".
I'm Vooming.
And it only took two calls to get activated.
I'm Vooming.
