622 and 211 HDMI audio users
williamkmurphy
Thread Starter
142
Bills Country
Does anyone know if dish has any plans to enable either DD5.1 or 6 channel pcm on the 211?
Does the 622 already do this or are you guys stuck with optical for anything better than 2-channel?
I want full functionality!!
bhelms
Retired & lovin' it!
7,795
853
Central PA
IIRC the 622 outputs only DD 2.0 through the HDMI connection. For anything better you need to use the optical port. Sorry but I can't speculate on any plans for either receiver...
Jim5506
7,821
2,792
Lubbock, Texas
The problem is not that the 622 only outputs DD2.0 on HDMI, it is that very few surround systems can decode 5.1 or higher through the HDMI port.
williamkmurphy
Thread Starter
142
Bills Country
Is the output in DD2.0 or is it in 2 channel PCM. My receiver shows PCM as the audio format when I use the HDMI audio from the 211. Shows a mix of PCM and DD5.1 depending on the channel when I use optical.
Its too bad that I don't have anything else that puts audio out over hdmi to test this theory. I am fairly confident that the yamaha will support 8-channels of audio through the HDMI port in either a compressed (DD,DTS format) or uncompressed. It doesn't have to decode anything (in a DTS, DD sense) if the audio is already in PCM.
The receiver is a yamaha rx-v2600 fyi.
