622 SD (NTSC) output behavior *$&#^@)
N
noremac
Thread Starter
251
Wash, DC
I just got my 622 installed, and immediately don't like the way it handles NTSC output compared to my 811 (which was perfect). Please tell me if I'm doing something wrong!
Here's what I want: Simultaneous HD (1080i) output to an HD set and SD (NTSC) output to a regular TV without any distortion of the NTSC picture or HD picture. Also, I want to use Single Mode so either the HD or SD set has access to OTA digitals.
Unfortunately, the only way I seem to be able to get a distortion-free NTSC image is to use the 4:3 #2 aspect setting. But that screws up the HD output!
I have also played with every combination of the Format (*) key to no avail. The 811 had separate Format settings for both SD and HD outputs, but the 622 keeps them sync'd together.
This stuff gets complicated, so I may not be explaining it all well. I'll think about making a chart or something...
G
garys
Not what normac is talking about. What he is saying, while in single mode, if sd is set at normal on HD output and you look at tv2 outputs, the sd picture is compressed and black side bars are still visable. But in dual mode sd picture needs to be normal on tv2. No matter what outputs you use.
N
noremac
Thread Starter
251
Wash, DC
garys said:
...No matter what outputs you use.
Correct. I actually tried composite, S-vid and RF. The behavior is all the same. :mad:
You can sorta correct SD source material when viewing on the SD set by choosing the Stretch format option. But there is no way to view HD source material on the SD set without either (a) distortion or (b) cropping the L & R sides.
What amazes me is that Dish did a great job handling all the simultaneous SD & HD format possibilities on the 811 model. You can just about do anything with it.
Similar threads
J
Replies
Views
1K
jrchip01
J
vtjman
Replies
7
Views
2K
bighick
B
M
Replies
6
Views
4K
dare2be
dare2be
H
Replies
6
Views
2K
SimpleSimon
SimpleSimon
H
Replies
5
Views
2K
kstile
kstile
