722 Pixilated recordings.
tomterrific
3
I have a new 722 installed on Jan. 28th. I have had two problems with recording. Picture was scrambled (pixilated) when I viewed it after it had started recording. Both recordings were set up in advance. It happened again the next day on a different channel. Both receivers had a good signal and clear weather.All of the other programs were recorded successfully. All other functions; pause, FF, skip ahead, skip back, etc. function normally. So far it has only happened on a standard def. Chnl. All HD recording are ok, and all SD recording are ok except these 2.
Anyone else had a similar problem?
I was trying to record Futurama on channel 107, sat 119 TX. 13
and CSI on channel 169, sat 119 TX. 14 It records ok most of the time.
NHL CI HD schedule (Pathetic)
