722 pulling two IPs
Actually, I should clarify. With Class A you have 16.7 million possible hosts (256 * 256 * 256), but with Port Address Translation, since TCP and UDP port numbers are 16 bits long, you'd "only" be able to have 2 ^16, or port numbers 0 through 65,535, thus "limiting" you to 64,000 or so devices on your home network.
Aw crap!!! That changes everything!!!!:D
Thanks for the help. It's not hurting anything. I was just curious as to why. I was also wondering why the IPs are 10.x.x.x, and not the standard 192.168.x.x? It even states in the instructions and notes that 192.168.x.x is the default. Should I change these or leave it alone?
I think I can answer this one as I just ran into it last week. Netgear routers will change their LAN IP scheme to 10.x.x.x without warning if they see a 192.168.x.x network on the WAN port. In my case it was a rouge DHCP server on the network caused by someone having a router's WAN cable hooked up to one of the LAN ports by mistake.
This can also be caused by some cable and DSL modems that have embedded management servers operating in a 192.168.x.x scheme.
More info here: http://forum1.netgear.com/showthread.php?t=29096
sigmtr
Do external hard drives have to be upright?
Replace Separator
