722k giving a complete signal loss message every five minutes and the reboots.
1hotwire
Pacific Northwest
My 722K that I own has started giving me problems. Approximately every five minutes it will display a message that says complete signal loss and then the receiver will reboot. The receiver was plugged into a power strip, I tried plugging the cord directly into the wall and there was no change in behavior. I did a check switch test and it didn't show any errors or problems.
If I disconnect the RG-6 cable coming from the satellite dish, the receiver behaves normally. I am able to watch recordings off of the DVR with no rebooting problems. Does anyone know if this is a dish/LNB problem or a receiver problem?
Thanks for your help,
Kenny
Bypass the diplexer or triplexer and connect the line directly to the sat feed and run a check switch. Does it still reboot and display signal loss?
If the LNB cable is disconnected from the receiver and the receiver doesn't reboot I'd look for a cable or LNB problem. A guess would be a short, try removing cable from switch/LNB then connecting to receiver if it reboots replace the cable.
How long does it take Dish to email a certificate number?
PTAT Saved Shows and extended time or padding question
