722k on lcd monitor
Well, yes there is. The HDMI output of the 722 can be cabled up to the DVI input on the monitor. There is no analog output of the 722 (such as component) that a VGA monitor could understand. (Former is YPbPr, latter is RGB.)
The HP 2009M will support up to 1600x900 resolution. You could use one of these guys and hook it up to either the TV1 or TV2 composite output.
For only $1.62 each when QTY 50+ purchased - VGA to S-Video/RCA (Composite) Adapter Cable - Black | VGA <--> S-Video/RCA
Ah... According to the link you gave,
IMPORTANT:
  • THIS ADAPTER WILL ABSOLUTELY NOT CONVERT AN S-VIDEO OR COMPOSITE VIDEO SIGNAL TO VGA. IT WILL NOT WORK BACKWARDS.
  • YOU CAN NOT USE IT TO DRIVE A VGA COMPUTER MONITOR WITH A CONSUMER ELECTRONICS DEVICE SUCH AS A DVD PLAYER OR VCR.
  • IT IS NOT COMPATIBLE WITH NETBOOKS OR ANY CURRENT GRAPHIC CHIPSET.
