OTHER 8dtek Desired
The spectrum scan takes a few seconds to stabilize, I do not know the sweep rate and am sure it's not real-time.
Most receivers use % signal quality, maybe the more sophisticated satellite meters show dBm.
The default range is 11700 to 12900 MHz but can be changed to anything you want. The default spectrum scan takes about 8 seconds. Also the display shows the downconverted frequency ie. 950-2150.
I connected a 7" LCD to the video output and get full screen color display. It is an Axess brand from Amazon.
waltmap did you notice if you hook up the meter A/V output to a regular TV that the video is truncated at the edges and the quality of the video is poor? I was told the format was PAL.
AMIKO AMIKO A3
Amiko Mini HD SE Backups
