ocaddict said:What's the sense in hooking up a 921 to an antiquated CRT non-widescreen TV? Your best bet is to get a good TV first, then move to a 921. Otherwise it doesn't really make sense. You woulnd't put a 4cyclinder engine in your new Ferrari would you?
Yes, it will make a difference. Regular TV is what 5:4 ratio? Ok The 1080i nd 720p work with the 4:3 ratio as well as the 16:9 ratio. If you use the 1080i it makes the picture bigger but the standard broadcast picture are going to be smaller. The standard picture is not as small in the 720p format and would be the same size in the 480p. Higher res. means smaller pixels.birkoff said:I have a 6000 and regular 4:3 HD TV,
and the non-HD channels are
reduced in size. Does the 921 also reduce
the size or are they full size, like the 721?
birkoff
