Seadoo said:
boy921:
In answer to the timer issue.
1. Hit DVR button to come up with list of recorded events and timers.
2. I normally would assume that to go to the timer list all I would have to do is hit TIMER button on right, but when I do nothing happens.
3. In order to go to the Timers I first must select any of the active timers I have and then hit the TIMER button on right, which seems odd to me.
4. Once I get in Timer menu I have to reselect a timer if I want to edit.
Question is why can't I go directly to the TIMER menu without having to go through this procedure?
I will try your procedure in getting rid of ghost favorite lists.
OK, I experience the same thing, kinda. when I'm in the DVR menu and hit the timer button, it just scrolls down to where my listed timers are. Not much of a short cut
It seems that it would take you to the real timer menu. I think this is just a shortfall in software design. Hopefully, in future software releases, they will make this so we actually can go to timers. Now if you do hit your timer button in the DVR menu, if you have any timers, it should scroll down to them. What you can do is select any one of the timers then hit your select button. this will take you into timer management. The only thing is just takes you to the list of created timers but not the specific one that you chose in the DVR screen.
