A Shame Thread
A double stacked lo-pro, with EL/AZ broke off for the middle tie-together, on an under eave mount with studs hit on one side only, no corner braces, and pointed right at trees during a winter install, service out at beginning of spring.
the other one is a LO,LO pro
You mean like these?
Reactions: Tylorert
The "anchored" pole
the country pole
the line of sight boost
Lo,Lopro on a rail
one block non-pen
I could do this all day
Tons of jobs by power lines.
I can'tfind my favorite right now tho, its grounded to a gas main
One time i was in the country no hardware store in sight and had no tapcons, i predrilled the holes in the brick stuffed the holes with the plastic part of the flex clips and then lag screws, dish500 felt solid i know it lasted at least 90 days
Reactions: hank123
you realize you are the type of installer being made fun of right?
that low-low pro is classy. i've got a picture of a rail mount attached to a 2.5" pole, and a low pro on a flat roof mount kicking around here somewhere. they're both AT&T uverse installers.
Reactions: Hutch1814
The amount of garbage I seen in 7 years makes these installs look like perfect Installs.
Sent from my iPhone using SatelliteGuys mobile app
Low pro on a sled? Ive done that, if i didnt have a sled i would just use 5 cinder blocks, a low pro and 4 support arms
Im not an installer
Can we just leave this forum to pics of bad installs with explanation? Whats interesting to see it the funny ones!
Center Ice subs now include access to NHL.tv
rvu with avr question
