Can anyone guess what the real problem was?
techristian
10
6
Windsor
The box always worked SORTOF but lately , I was unable to tune in channels.
Someone here suggested a new power supply. Good suggestion. It worked a little better for a little while but after warming up NO CHANNELS. Warming up? Maybe it needs better cooling. So I hacked it and installed a fan. See photo.
That only worked for a 15-20 minutes. Can anyone guess what the real problem was?
My guess would be the switch, not the box.
You mentioned in your other thread that you have four dishes running through an 8-way switch that has been sitting in the garage for at least ten years. That is the one part of the chain you have not swapped yet, and it fits the pattern perfectly: everything works for 15 to 20 minutes, then as the switch itself warms up, a cold solder joint or a tired component inside it loses contact and the signal path drops out completely. A new power supply and a fan on the box would both help a little at first, which is exactly what you saw, because they take some load off a marginal connection, but they do not fix it.
The quick test is to take the switch out of the picture entirely. Run a single dish straight into the receiver with a short piece of coax, tune a channel on that satellite, and leave it running for an hour. If it stays locked the whole time, the box and the LNB are fine and the switch is the problem. If it still dies after 15 to 20 minutes on a direct connection, then it really is heat inside the receiver, most likely dried-out capacitors around the tuner, and the box is on its way out.
If it is the switch, check the F-connectors on it as well. Ten years in a garage is a long time for the centre pin and the braid to corrode, and a loose or green connector will behave exactly like this.
Why my FTA box stopped working?
