Advanced Question for MrTim ****
thepackrat
9
A very good customer of mine recently brought me a T-100 that someone had tried to hack.
I want to RESTORE IT to FACTORY SPECIFICATIONS for him.
I am an ADVANCED electronics technician with over 30 years experience.
I am a LEGITIMATE repair shop.
I DO NOT DO FREE TV.
My questions are;
A) Is there some kind of " write protected " sectors on the TE28F160-C3TD70 ?
B) Does this unit use some kind of non-standard sectoring ON the TE28 ?
1) The unit powers up but gives NO DISPLAY.
2)The unit will NOT accept a write from the " updater " software.
3) ALL voltages are present on main board and within the chips data-sheet specs.
4) There are NO missing parts , and no damaged traces or via's.
5) The Sti and TE28F are both recognized and properly initialized when jtagged. (I re wrote a jkeys "def" file to support every mode the TE28F160-C3TD70 data sheet SAYS it can support)
6) It APPEARS to " go through the motions " in both the flash programming and in the development panel ...( used the factory bin from your site) ... but the unit refuses to come back to life.
I am NOT looking for a return authorization to have YOU fix it ... ( I KNOW you support your customers with quality products and services ...and have legitimate concerns over quality control and product liability ) ... and I would USUALLY just give the customer a stern lecture on buying used equipment from "shady" characters ...but this is a loyal customer, and sometime I have to EAT the cost of a " dog repair " to keep THIS kind of customer happy.
ANY help you can give me would be greatly appreciated.
I didn't want to pm him " out of the blue " ...
... guy probably has a plate full of PM and I didn't wanna' add another slice !
:-P
Did the receiver work before you tried to restore it? If somone tried to hack it, they may have caused the CPU to stop accepting commands. I am not familiar with the receiver you have, but there are ways to revive most receivers that have died from somone trying to hack it. Messing with non-standard firmware is not only flirting with trouble, and the law, it is also a good way to kill a receiver in one easy step. You might want to search the internet for the term J-tag. This is the method used to revive a receiver that it dead from receiving bad firmware. It basically involves building an interface to the Motherboard/CPU so you can trigger the CPU to boot a new program. Bootstrap comes to mind.
Good luck... Joe
No it did not work at all when it was brought into the shop.
I SHOULD have said I ASSUME that someone tried to hack it.
I agree with you 100% and that is what I am ASSUMING was done to this one. As I stated in my first post..there does not seem to be any ELECTRONICS HARDWARE related problems with this unit ...( unless mrtim answers my question with some electrinics test that I can do to find some obscure hardware related problem...)...so I immediately suspected a FIRMWARE problem.
My customer is a Portugese immigrant and his english is a bit hard to understand at times...but from what I can understand HE purchased the unit from a third party ($50 for unit , dish, remote, LNB, etc...) expecting to be able to watch his Portugese channel. I am SURE My customer did NOT try to "hack " it himself because he has NO technical skills at all ...and KNOWS it !! ( He once called my shop to see if it was OK to use a 15 watt APPLIANCE bulb in a " table lamp " ) ...BUT... he DOES call me in for ALL his consumer electronics repairs, and has recomended a LOT of other customers to me ...so I do not want to let him down.
The OTHER side of the coin is that this unit is VERY affordable, and IF I feel confident that I can service it in my shop, then I MIGHT be able to get quite a few sales/installs from this guys friends and family !
I have a "basic working knowlege" of boundry scan technology and have already tried applying the factory firmware ( found on the company web site ) to this unit. I have a computer on my workbench DEDICATED to servicing firmware related problems... ( RCA TV's are SO notorious in the service industry for firmware related problems that there is a whole industry based on it ! ...google " chipper checker " and you'll see what I mean ! ) ... I KNOW my service bench equipment is working correctly and yet ...even thought this unit " went through the motions " of correctly restoring the factory firmware ... the unit remains comatose .
Technojunky said:
Good luck... Joe
Thank YOU !
TPR
PS ....
...I PM'd MrTim and pointed to this thread ...but have not recieved any kind of answer yet.
help to setup my dish with motor
A good system for Pennsylvania?
