Analog and Digital FTA
PopcornNMore
3,635
128
Gibsonia, PA
I just purchased a Coolsat 4000 Pro, standard KU LNBF and a SG2100 H-H motor.
I would like to use one of my old C/KU band analog IRD's to receive the many analog KU FTA channels still available.
My question is how would I hook up the receivers? I am assuming I would connect the standard KU LNBF to the IF input of the Coolsat and the IF output on the Coolsat to the IF input on the analog IRD.
Would I then connect the video / audio outputs on the analog IRD to the TV or would I need to connect both the Coolsat and analog IRD video / audio outputs to the TV and switch inputs on the TV?
I almost went with the Pansat 2700A, but Iceberg's review on the Coolsat convinced me to buy the Coolsat instead. I am sure I will be 100% happy it seems to be a great receiver.
Dave :)
Yes Iceberg has certainly boosted the sales for the Coolsat, they should send him one for free : )
The audio/video cables should be hooked directly (independently) to the TV, thats how my Digital/Analog system works.
Thank you Pete, that does make sense. I assume the IF hook-up is correct as well with the signal from the LNB going into the Coolsat receiver first then to the analog IRD?
What I have is my Coolsat hooked to the dish/LNB. From the loop out, I go to my analog receiver (an old Toshiba)
I have both through a VCR….video 1 is the coolsat and video 2 is the Toshiba
Thank you once again Iceberg!
I was wondering if there is any loss when attaching the coax to hookup the SG2100 H-H motor? When bypassed and set to a single satellite, is the signal strength higher?
nope.
I just did a test a while back to see if the DirecPC that I just got (35x20) was better than the 30" motorized and the numbers were identical. The motor is just a passthrough
Wrong LNB / Wrong Satellite?
Cannot find any chanels
