antenna question
mikedz4
714
9
My xm satellite radio reception stinks. There are alot of areas where the service cuts out. I was looking at a new larger antenna the only problem is I use sureconnect. Even the new antenna that came with my new xm satellite radio can't be used because it isn't sureconnect. Are there any large antennas for xm that have sure connect?
thank you
I don't think it matters what type of antenna you have just because you use SURE CONNECT. What kind of XM receiver do you have?
i have the xpress rc. I was looking for a larger antenna that isn't as succeptible to blockage from tall hills or trees.
All I can suggest is to buy a semi truck antenna but that may still not work. If you buy one at a truck stop, keep the receipt. :)
do semi truck antennas work with sure connect? the xpress rc can ONLY be used with sure connect or direct connect.Where can i find a magnetic high gain antenna for xm? I've found some for sirius but not xm.
Free Channels Coming to XM?
Turning Xm Into Sirius
