Anyone seen this?
Richard Fuller
48
I've seen this a couple of times on my tv when watching voom it is what appears to be to small white lines. At first I thought it was something wrong with my tv but when I switched to dish or directv the lines disappear anyone else seen these.
Most likely you are seeing stuck pixels after navigating in the PG - a known issue in the current software version. Just press VOOM and then WATCH to get rid of them.
Ilya...
Is that the same issue that causes the "white spot" that won't go away?
I thought it took a reboot to get it to vanish?
If the spots are very pronounced (stuck white pixels) and are present on all channels, then the VOOM-WATCH trick should do it. If the spots are not very noticeable and are present on SD channels only, a reboot might be needed. If the spots are present on a single channel only, this is probably a source issue: not much you can do.
Just signed up for Voom
Looking for tips adding Voom.. (after E* and D*)
