What bothers me here is that when Gemini makes a specious claim, the citation it links to too frequently doesn't support the assertion. Come to think of it, this happens most often with Reddit citations.
In the DIRECTV subreddit in particular, there have been quite a few instances where the initial post is deleted, yet the responses remain.
Because it's an interpretation. One of the fundamental things to learn about AI is deterministic vs non deterministic behavior. When you ask it something, you're getting a non-deterministic response, meaning it is interpreting and providing a response based on processing that data. That doesn't mean it will always be accurate or that it will be the same every time.
An example - if you wanted a report created from a set of data, you don't use a LLM for that, because you don't want the data interpreted every time you pull that report, no you want that data consistently reported on. So you use a LLM to create the script / mechanism / page / etc so that it pulls and creates that report every single time - a deterministic action - rather than asking for the data to be interpreted every time.
It may seem like a simple thing, but once you understand the concept, it makes some sense why you see variability in things from time to time or anomalies like what you caution against here.
There are other wrinkles as well - the model presents the answer to a query, then attaches the closest-looking source, which doesn't always actually support it. Reddit makes this worse when the OP is deleted, because the model is reading replies without the original question.
And then after all of that, it doesn't mean the data (training or references) is even correct
On the topic overall though - it's just a matter of learning the tool. Learning when to check and further interrogate your sources - just like 'knowing how to Google'.
