Bsc-421 Lnbf
W_Tracy_Parnell
1,740
3
South of Buffalo NY
Thinking of getting one of these for a "mini-bud" project. A couple of questions:
1. What is the difference between this and the ASC-421?
2. What dishes will work with this? I would be looking around for a free dish for right now.
The below info came directly from the importer :)
"BSC is the latest technology. By consolidating many of the components into a chip, they are able to have better stability and lower noise while increasing the gain.
BSC technology also lowers the failure rate. Although the ASC LNB/Fs had a very low failure rate, the BSC technology is proven to have a even lower failure rate.
BSC technology is the biggest advancement in LNB/Fs for years"
Seems there will be many more BSC LNB's in the works (Duals / Quads....) :)
I'll probably go with the BSC then. If the gain is a little higher it should about match the C/KU LNB combo which if I remember right you reported had maybe a 3-5 % gain over the ASC.
How to move polarotator
AlJezeera English debut?
